Показано с 1 по 3 из 3
Тема: Беспроводная зарядка WIRELESS CHARGER Mitsubishi Outlander IV 2.5 CVT (2022 MY ->)
    Вопросы по работе беспроводной зарядки смартфона/телефона Mitsubishi Outlander IV 2.5 CVT (2022 MY ->) задаем в этой теме
    Некоторые комплектации Mitsubishi Outlander IV 2.5 CVT (2022 MY ->) оборудованы беспроводной зарядкой смартфона/телефона
    беспроводная зарядка WIRELESS CHARGE 8638A320
    индикатор WIRELESS CHARGE 8638A321
    Беспроводная зарядка Wireless charging Mitsubishi Outlander IV 2.5 CVT (2022 MY ->)
    Миниатюры Миниатюры 2021-nissan-rogue-features-connectivity-charging.jpg‎   428396A4-1947-4040-A1EE-E6F5C78E2325.jpg‎   20703179-DDBE-4D9F-8467-F6B68062791D.jpg‎
    WIRELESS CHARGER Mitsubishi Outlander IV 2.5 CVT (2022 MY ->) (if so equipped)
    The wireless charger is located on the lower part of the instrument panel. Lay the smartphone on the pad of the wireless charger.
    Charging will start automatically. The smartphone will be charged continuously while the ignition switch is in the ON position.
    WARNING
    . Never put metallic materials between the wireless charger and a smartphone.
    . Those who use a pacemaker or other medical equipment should contact the electric medical equipment manufacturer for the possible influences before use.
    . Never put cloth over the smartphone during charging process.
    . Never charge a smartphone when it is wet.
    . Never put metallic materials or small goods such as a cigarette lighter.
    . Never put F.A.S.T.-key near the wireless charger.
    CAUTION
    . Do not put an RFID/NFC card between the wireless charger and a smartphone. This could cause data corruption in the card.
    . Do not use the wireless charger with dust accumulated or dirt on the pad.
    . Do not hit the surface of the wireless charger.
    Wireless charger Indicator
    The indicator will illuminate in orange when the charging process is started.
    When the charging has completed, the indicator illuminates in green.
    If a malfunction occurs or the charging process has stopped, the indicator will blink in orange.
    Operation of the wireless charger
    To use the wireless charger, it is necessary that the coil in the charging pad aligns with the coil in your smartphone. The most efficient area for charging is just on the "Qi" logo. Place the coil of your smartphone in the charging pad, targeting on the "Qi" logo. Because the location of the coil varies depending on the smartphone, you will need to try and find the area that suits your smartphone.
    Because some smartphone cases or accessories may adversely affect charging, remove them before wireless charging.
    Turn off the vibration function of the smartphone before wireless charging.
    NOTE:
    . Only a Qi compatible smartphone can be used.
    . The smartphone may be warmed during charging process and the charging may stop by the protection function of the wireless charger. This is not a malfunction. If this occurs, restart charging after the smartphone cooled down.
    . The wireless charging process may be stopped by the status of the smartphone (battery temperature, etc.).
    . If a radio noise interference occurs during charging process, put the smartphone’s coil position onto the center ("Qi" logo) position of the wireless charger.
    . The wireless charging process will stop during process of searching the F.A.S.T.-key.
    . The wireless charging process will not be started when a USB (Universal Serial Bus) cable is connected to the smartphone. The indicator may illuminate in orange or blink if the smartphone is put on the wireless charger with a USB cable connected. However, charging is not performed.
    . Depending on the type of the smartphone, the indicator may remain illuminated in orange even when the charging process has been completed.
Название: Wireless charger Indicator.png
    БЕСПРОВОДНОЕ ЗАРЯДНОЕ УСТРОЙСТВО Mitsubishi Outlander IV 2.5 CVT (2022 MY ->) (при наличии)
    Беспроводное зарядное устройство расположено в нижней части приборной панели. Положите смартфон на площадку беспроводного зарядного устройства. Зарядка начнется автоматически. Смартфон будет постоянно заряжаться, пока ключ зажигания находится в положении ON.
    ПРЕДУПРЕЖДЕНИЕ
    . Никогда не кладите металлические предметы между беспроводным зарядным устройством и смартфоном.
    . Тем, кто использует кардиостимулятор или другое медицинское оборудование, перед использованием следует обратиться к производителю электрического медицинского оборудования, чтобы узнать о возможном влиянии.
    . Никогда не накрывайте смартфон тканью во время зарядки.
    . Никогда не заряжайте смартфон, если он мокрый.
    . Никогда не кладите металлические предметы или мелкие предметы, такие как зажигалка.
    . Никогда не кладите F.A.S.T.-ключ рядом с беспроводным зарядным устройством.
    ОСТОРОЖНОСТЬ
    . Не кладите карту RFID/NFC между беспроводным зарядным устройством и смартфоном. Это может привести к повреждению данных на карте.
    . Не используйте беспроводное зарядное устройство, если на подушке скопилась пыль или грязь.
    . Не ударяйте по поверхности беспроводного зарядного устройства.
    Индикатор беспроводной зарядки
    Индикатор загорится оранжевым, когда начнется процесс зарядки.
    Когда зарядка завершена, индикатор загорается зеленым цветом.
    При возникновении неисправности или остановке процесса зарядки индикатор будет мигать оранжевым цветом.
    Работа беспроводного зарядного устройства
    Чтобы использовать беспроводное зарядное устройство, необходимо, чтобы катушка в зарядной панели совпадала с катушкой в ​​вашем смартфоне. Наиболее эффективная зона для зарядки находится как раз на логотипе «Qi». Поместите катушку вашего смартфона в зарядную панель, ориентируясь на логотип «Qi». Поскольку расположение катушки зависит от смартфона, вам нужно будет попытаться найти место, подходящее для вашего смартфона.
    Поскольку некоторые чехлы или аксессуары для смартфонов могут отрицательно сказаться на зарядке, снимите их перед беспроводной зарядкой.
    Отключите функцию вибрации смартфона перед беспроводной зарядкой.
    ПРИМЕЧАНИЕ:
    . Можно использовать только Qi-совместимый смартфон.
    . Смартфон может нагреваться в процессе зарядки, и зарядка может быть остановлена ​​функцией защиты беспроводного зарядного устройства. Это не является неисправностью. В этом случае перезапустите зарядку после того, как смартфон остынет.
    . Процесс беспроводной зарядки может быть остановлен состоянием смартфона (температура аккумулятора и т. д.).
    . Если во время зарядки возникают радиопомехи, поместите катушку смартфона в центральное положение (логотип «Qi») беспроводного зарядного устройства.
    . Процесс беспроводной зарядки остановится во время поиска F.A.S.T.-ключа.
    . Процесс беспроводной зарядки не будет запущен, если к смартфону подключен кабель USB (универсальная последовательная шина). Индикатор может светиться оранжевым цветом или мигать, если смартфон находится на беспроводном зарядном устройстве с подключенным кабелем USB. Однако зарядка не производится.
    . В зависимости от типа смартфона индикатор может оставаться оранжевым даже после завершения процесса зарядки.
  1. Ответов: 4
    Последнее сообщение: 08.12.2023, 09:37
  2. Ответов: 6
    Последнее сообщение: 05.12.2022, 20:47
  3. Ответов: 6
    Последнее сообщение: 14.06.2022, 15:12
  4. Ответов: 4
    Последнее сообщение: 23.12.2021, 09:43
  5. Out III: Зарядка для телефона в Mitsubishi Outlander III. USB порт для зарядки
    от ded1969 в разделе Электрооборудование и электроника, автозвук
    Ответов: 17
    Последнее сообщение: 31.05.2018, 17:53
