Показано с 1 по 2 из 2
Тема: Указатель пробега до планового ТО (напоминатель ТО) Mitsubishi Outlander IV 2.5 (2022 MY ->): принцип работы, как настроить, самостоятельный сброс
    Указатель пробега до планового ТО Mitsubishi Outlander IV 2.5 (2022 MY ->) (напоминатель): принцип работы, как настроить, самостоятельный сброс
    Напоминатель ТО Mitsubishi Outlander IV 2.5 (2022 MY ->).
    Напоминатель техобслуживания Mitsubishi Outlander IV 2.5 (2022 MY ->).
    Сброс счетчика межсервисного интервала ТО Mitsubishi Outlander IV 2.5 (2022 MY ->)
    Индикатор технического обслуживания Mitsubishi Outlander IV 2.5 (2022 MY ->)
    Maintenance MULTI-INFORMATION DISPLAY
    The maintenance mode allows you to set alerts for the reminding of maintenance intervals. The displayed menu items vary depending on the vehicle’s equipment. To change an item:
    Select “Maintenance” using the scroll dial and push it.
    . Oil Control System (if so equipped)
    . Oil and Filter (if so equipped)
    . Tire
    . Other
    Oil Control System (if so equipped):
    The oil control system can be accessed in the Maintenance portion of the multi-information display settings.
    10,000 miles (16,000 km) between oil change intervals for the PR25DD engine.
    The oil change interval cannot be adjusted manually.
    The distance to oil change interval is calculated depending on the driving conditions and set automatically by the oil control system. A
    reminder will be displayed when approaching the end of the service interval.
    When the Factory Reset option is selected in the multi-information display, the oil control system will also be reset to initial value. Please
    change the engine oil when Factory Reset is selected.
    If the oil replacement indicator is displayed, change the engine oil within two weeks or less than 500 miles (800 km).
    Operating the vehicle with deteriorated oil can damage the engine.
    To reset oil control system:
    1. Place the ignition switch in the ON position.
    2. Push the and buttons on the steering wheel until “Settings” appears in the multi-information display. Use the scroll dial to select “Maintenance”. Then, push the scroll dial.
    3. Select the “Oil Control System” and push the scroll dial.
    4. Push the scroll dial according to the reset instructions displayed at the bottom of the “Oil Control System” maintenance screen.
    Oil and Filter (if so equipped):
    This indicator appears when user set distance comes for changing the engine oil and filter.
    You can set or reset the distance for checking or replacing these items.
    МУЛЬТИИНФОРМАЦИОННЫЙ ДИСПЛЕЙ Режим технического обслуживания Mitsubishi Outlander IV 2.5 (2022 MY ->)
    Режим технического обслуживания позволяет настроить оповещения для напоминания об интервалах технического обслуживания.
    Отображаемые пункты меню различаются в зависимости от комплектации автомобиля.
    Чтобы изменить элемент:
    Выберите «Обслуживание» с помощью диска прокрутки и нажмите его.
    . Система контроля масла (при наличии)
    . Масло и фильтр (при наличии)
    . Шина
    . Другой
    Система контроля масла (при наличии):
    Доступ к системе контроля масла можно получить в разделе «Техническое обслуживание» настроек многофункционального информационного дисплея.
    10 000 миль (16 000 км) между интервалами замены масла для двигателя PR25DD.
    Интервал замены масла нельзя отрегулировать вручную.
    Расстояние до интервала замены масла рассчитывается в зависимости от условий движения и автоматически устанавливается системой контроля масла. А
    напоминание будет отображаться при приближении к концу сервисного интервала.
    Когда на многофункциональном дисплее выбрана опция Factory Reset, система контроля масла также будет сброшена до исходного значения. Пожалуйста
    замените моторное масло при выборе Factory Reset.
    Если отображается индикатор замены масла, замените моторное масло в течение двух недель или менее чем через 500 миль (800 км).
    Эксплуатация автомобиля с испорченным маслом может привести к повреждению двигателя.
    Для сброса системы контроля масла:
    1. Установите ключ зажигания в положение ON.
    2. Нажимайте кнопки и на рулевом колесе, пока на многофункциональном дисплее не появится надпись «Настройки». С помощью диска прокрутки выберите «Обслуживание». Затем нажмите диск прокрутки.
    3. Выберите «Система контроля масла» и нажмите диск прокрутки.
    4. Нажмите ручку прокрутки в соответствии с инструкциями по сбросу, отображаемыми в нижней части экрана обслуживания «Система управления маслом».
    Масло и фильтр (при наличии):
    Этот индикатор появляется, когда пройдено заданное пользователем расстояние для замены моторного масла и фильтра.
    Вы можете установить или сбросить расстояние для проверки или замены этих элементов.
  1. Ответов: 130
  2. Ответов: 25
    Последнее сообщение: 19.07.2023, 05:03
  3. Ответов: 263
    Последнее сообщение: 04.04.2022, 19:29
  4. Ответов: 27
    Последнее сообщение: 04.04.2022, 19:11
  5. ASX: Указатель пробега до планового ТО Peugeot 4008, Mitsubishi ASX и Citroen C4 Aircross
    от zharygin в разделе Электрооборудование и электроника, автозвук
    Последнее сообщение: 12.11.2015, 07:31
