В Mitsubishi Outlander IV 2.5 CVT имеется 4 USB порта:
- впереди 2 разъема USB: USB-A и USB-C
- сзади 2 разъема USB: USB-A и USB-C
розетка с разъемами USB-A и USB-C передняя 8718A073
розетка с разъемами USB-A и USB-C задняя 8638A491
Характеристики USB разъем Mitsubishi Outlander IV 2.5 CVT:
Type-C port: 5 volt, 15W, 3A
Type-A port: 5 volt, 12W, 2.4A
передний блок розеток 8718A073
блок розеток 8718A073, справа - индикатор беспроводной зарядки 8638A321
задний блок розеток 8638A491 (снизу под климатом)
USB (Universal Serial Bus) CHARGING OUTLET Mitsubishi Outlander IV 2.5 CVT (2022 MY ->) (if so equipped)
The USB charging outlet is located on the back of the center console box.
The USB charging outlet can be used only for charging an external device.
Connect a USB device into the connector. Charging will start automatically.
The maximum output of each port is:
- Type-C port: 5 volt, 15W, 3A
- Type-A port: 5 volt, 12W, 2.4A
The external device will be charged continuously while the ignition switch is in the ACC or ON position.
Do not charge many devices at the same time by using a multi-plug adapter.
Do not allow water or any liquid to contact the outlet. If liquid splashed on the charging port or the charging port is clogged, it is recommended to contact an authorized Mitsubishi Motors dealer.
Some mobile devices cannot be charged depending on their specifications.
CAUTION
. Using charging connectors without engine running may cause the vehicle battery discharge.
. Before using the USB charging outlet, be sure the charging port is not clogged. If the charging port is clogged, it can be a cause of short-circuit and the connected device and the charging port might be damaged.
. Do not force a USB device into the connector. Inserting the USB device tilted or up-side-down into the connector may damage the connector. Make sure that the USB device is connected correctly into the connector.
Do not use a reversible USB cable. Using the reversible USB cable may damage the connector.
USB-разъем для зарядки Mitsubishi Outlander IV 2.5 CVT (2022 MY ->)
USB-разъем для зарядки расположен на:
- передней центральной части торпедо
- задней части ящика центральной консоли
USB-разъем для зарядки можно использовать только для зарядки внешнего устройства.
Подключите USB-устройство к разъему. Зарядка начнется автоматически.
Максимальный выход каждого порта:
- Порт Type-C: 5 вольт, 15 Вт, 3 А
- Порт Type-А: 5 вольт, 12 Вт, 2,4 А
Внешнее устройство будет постоянно заряжаться, пока ключ зажигания находится в положении ACC или ON.
Не заряжайте несколько устройств одновременно с помощью адаптера с несколькими разъемами.
Не допускайте попадания воды или любой другой жидкости на розетку. Если на порт зарядки попала жидкость или порт зарядки забит, рекомендуется обратиться к авторизованному дилеру Mitsubishi Motors.
Некоторые мобильные устройства нельзя заряжать в зависимости от их характеристик.
ОСТОРОЖНО:
. Использование зарядных разъемов при неработающем двигателе может привести к разрядке аккумуляторной батареи автомобиля.
. Прежде чем использовать USB-разъем для зарядки, убедитесь, что порт зарядки не засорен. Если порт зарядки забит, это может быть причиной короткого замыкания, а подключенное устройство и зарядный порт могут быть повреждены.
. Не втыкайте USB-устройство в разъем силой. Вставка USB-устройства в разъем под наклоном или вверх дном может привести к повреждению разъема. Убедитесь, что USB-устройство правильно подключено к разъему.
Не используйте двусторонний USB-кабель. Использование двустороннего USB-кабеля может привести к повреждению разъема.
