Показано с 1 по 3 из 3
Тема: Система MI-PILOT Assist Mitsubishi Outlander IV 2.5 CVT (2022 MY ->)
    Работу MI-PILOT обсуждаем в этой теме
    Как работает MI-PILOT Assist Mitsubishi Outlander IV 2022MY-
    MI-PILOT ASSIST
    This section contains the information about the following system features:
    . MI-PILOT Assist (general system operation)
    . MI-PILOT Assist with Navi-link (additional functionality, if so equipped)
    WARNING
    Failure to follow the warnings and instructions for proper use of the MI-PILOT Assist system could result in serious injury or death.
    . MI-PILOT Assist is not a self-driving system. Within the limits of its capabilities, as described in this manual, it helps the driver with certain driving activities.
    . The MI-PILOT Assist system is not a replacement for proper driving procedures and is not designed to correct careless, inattentive or absent-minded driving. MIPILOT Assist will not always steer the vehicle to keep it in the lane. The MIPILOT Assist system is not designed to prevent loss of control. It is the driver’s responsibility to stay alert, drive safely, keep the vehicle in the traveling lane, and be in control of the vehicle at all times.
    . There are limitations to the MI-PILOT Assist system capability. The MI-PILOT Assist system does not function in all driving, traffic, eather, and road conditions. It is the driver’s responsibility to stay alert, drive safely, keep the vehicle in the traveling lane, and be in control of the vehicle at all times.
    . The MI-PILOT Assist system is only an aid to assist the driver and is not a collision warning or avoidance device.
    . The MI-PILOT Assist system is for highway use only and is not intended for city driving. Failure to apply the brakes or steer the vehicle when necessary may result in a serious accident.
    . Always observe posted speed limits and do not set the speed over them.
    . Never take your hands off the steering wheel when driving. Always keep your hands on the steering wheel and drive your vehicle safely.
    . Never unfasten your safety belt when using MI-PILOT Assist. Doing so automatically cancels the MI-PILOT Assist system.
    . The MI-PILOT Assist system does not react when approaching stationary and slow moving vehicles.
    . Always drive carefully and attentively when using the MI-PILOT Assist system.
    Read and understand the Owner’s Manual thoroughly before using the MI-PILOT Assist system. To avoid serious injury or death, do not rely on the system to prevent accidents or to control the vehicle’s speed in emergency situations. Do not use the MI-PILOT Assist system except in appropriate road and traffic conditions.
    The MI-PILOT Assist system is intended to enhance the operation of the vehicle when following a vehicle traveling in the same lane
    and direction.
    The MI-PILOT Assist system uses a multisensing front camera installed behind the windshield to monitor the lane markers and a
    radar sensor located on the front of the vehicle to measure the distance to the vehicle ahead in the same lane. If the system detects a
    slower moving vehicle ahead, the system will reduce the vehicle speed so that your vehicle follows the vehicle in front at the selected
    distance. The system will also help keep the vehicle centered in the traveling lane when clear lane markings are detected.
    MI-PILOT ASSIST SYSTEM OPERATION
    The MI-PILOT Assist system has the following two functions:
    1. Adaptive Cruise Control (ACC)
    The ACC system can be set to one of two cruise control modes:
    . Conventional (fixed speed) cruise control mode:
    For cruising at a preset vehicle speed
    For additional information, see “Turning the conventional (fixed speed) cruise control mode ON” (P.5-97).
    NOTE:
    Lane Keep Assist (LKA) is not available in the conventional (fixed speed) cruise control mode.
    . Vehicle-to-vehicle distance control mode:
    The ACC system maintains a selected distance from the vehicle in front of you within the speed range of 0 to 90 MPH (0 to 144 km/h) up to the vehicle set speed. The vehicle set speed can be selected by the driver between 20 to 90 MPH (30 to 144 km/h). When the vehicle ahead slows to a stop, your vehicle gradually decelerates to a standstill. When the vehicle is stopped, the ACC system maintains braking force to keep your vehicle stopped.
    . When your vehicle is stopped for less than approximately 3 seconds and the vehicle ahead begins to move, your vehicle will start moving again automatically.
    . When your vehicle is at a standstill for more than approximately 3 seconds and the vehicle ahead begins to accelerate, push up the RES+ switch or lightly depress the accelerator pedal. The ACC system starts to follow the vehicle ahead.
    . Always check surroundings before restarting the vehicle.
    . For vehicles equipped with MI-PILOT Assist with Navi-link and only when on a limited access freeway (as identified in the navigation map data):
    — The time the vehicle can remain stopped and automatically restart is extended from 3 seconds to 30 seconds.
    — If a vehicle ahead cuts in or out of the lane ahead, the vehicle may not automatically start when the traffic ahead begins to move. You need to push up the RES+ switch or lightly depress the accelerator pedal to follow the vehicle directly ahead when it is safe to do so.
    . When no vehicle is detected ahead within the driver selected distance, the vehicle travels at the speed set by the driver. The speed must be above 20 MPH (30 km/h) to use this function.
    NOTE:
    Even if the Automatic Emergency Braking (AEB) setting is turned off by the driver using the “Settings” menu in the multiinformation display, AEB will be automatically turned on when ACC is used.
    2. Lane Keep Assist (LKA)
    The Lane Keep Assist (LKA) function controls the steering system to help keep your vehicle within the traveling lane.
    When there is no vehicle ahead, Lane Keep Assist (LKA) is not available at speeds under 37 MPH (60 km/h).
    HOW TO CANCEL THE MIPILOT ASSIST
    To cancel the MI-PILOT Assist system, use one of the following methods:
    . Push the CANCEL switch.
    . Tap the brake pedal (except at a standstill).
    . Push the MI-PILOT Assist switch to turn the system off. The MI-PILOT Assist status indicator will turn off.
    When the MI-PILOT Assist system is canceled while the vehicle is stopped, the electronic parking brake is automatically activated.
    WARNING
    To prevent the vehicle from moving or rolling unexpectedly, which could result in serious personal injury or property damage, before
    exiting the vehicle make sure to push the MIPILOT Assist switch to turn the system off, push the park button to shift to the P (Park)
    position, and turn the engine off.
  1. Ответов: 6
    Последнее сообщение: 14.06.2022, 15:12
  2. Ответов: 5
    Последнее сообщение: 05.01.2022, 11:37
  3. Ответов: 1
    Последнее сообщение: 29.12.2021, 14:25
  4. Ответов: 4
    Последнее сообщение: 23.12.2021, 09:43
  5. Ответов: 8
