You are bidding on New Car Curtains/Sunshade 1set-2pcs.
Suitable for window Height 14"- 17.6" (35cm-44cm) & Width 20.4"-21.6"(51cm-54cm)
Product Features:
1.In use of UV resistant material.
2.Protect you from strong sunshine. Enhance your privet, prevent children from sunburn,
3. Fashionable design
4. Create business space inside of the car.
5. 3D adhesive tape and promoter
Universal type curtain install on your vehicle.
Easy to install and you can do it yourself.
The products is made by high-quality silk fabric required special care and handling. ( Claws & Hooks )
PRODUCTS CONTENT :
1. Drapery x 2
2. Pliable upper track x 2
3. Embroidered tieback x 4
4. Track cap x 2
5. Brush x 1
6. Primer adhesive promoter x 1
7. PDI clean package x 1
8.BSWC-1212EN
***Insist the best quality of brand "Car-Life" pursue the perfect project only use UV resistant material, Car-Life brand base the anti-fading test and get the certificate from national experimental organization. Anti fading coefficient up to 4.5 grade to insulate heat and prevent the Ultraviolet ray Enhance privacy etc.
Insist on best quality ,the top brand "car life" pursue the perfect project. Only use UV resistant material, Car life brand pass the anti-fading test and get the certificate from national experimental organization. Anti-fading coefficient up to 4.5 grade. Never to fade proved within 5 years.
Curtain from other brand , The UV rays and high temperature sunshine faded the curtain. The outside surface turn gray but the inside surface still keep the original color. You will feel this kind of curtain getting old in a short span. It also shows the anti-fading coefficient of curtain not good.
