Показано с 1 по 3 из 3
Тема: Рулевой наконечник Mitsubishi Eclipse Cross. Рулевая тяга Mitsubishi Eclipse Cross
    Все вопросы по замене, заменимости, партснамберам оригинала и заменителей (аналогов) рулевого наконечника Mitsubishi Eclipse Cross и рулевой тяги Mitsubishi Eclipse Cross обсуждаются в этой теме
    STEERING Mitsubishi Eclipse Cross-SEL-L4-1.5- Liter-GAS
    4410A328 BOOT - Steering Gear & Linkage - BELLOWSSTEERING GEAR
    4410A330 BOOT CLAMP - Steering Gear & Linkage - BANDSTEERING GEAR, Description : inner
    4410A329 BOOT CLAMP - Steering Gear & Linkage - CLIPSTEERING GEAR, Description : outer
    4410A852 GEAR ASSY - Steering Gear & Linkage - GEAR & LINK ASSY,STE
    4410A897 Gear assy mount bolt- Steering Gear & Linkage - BOLT,STEERING GEAR
    4422A143 INNER TIE ROD- Steering Gear & Linkage - TIE ROD,STEERING
    STEERING COLUMN & STEERING WHEEL Mitsubishi Eclipse Cross-SEL-L4-1.5- Liter-GAS
    8619A445 ANGLE SENSOR w/o touring package; Clockspring- Air Bag Components - SPRINGAIR BAG SENSOR; MODULES & SENSORS, w/o touring package
    8619A472 ANGLE SENSOR with touring package; Clockspring- Air Bag Components - SPRINGAIR BAG SENSOR; MODULES & SENSORS, w/touring package
    8600A739 COMBO SWITCH SEL, w/o touring package, MULTIFUNCTION SWITCH- Switches - SWITCHSTEERING COLUMN Eclipse Cross; SE, SEL; w/o Heated Strg. Wheel; Includes: Headlamp, Wiper & Turn Signal Switch.
    8600A748 COMBO SWITCH SEL, w/touring package, MULTIFUNCTION SWITCH- Switches - SWITCHSTEERING COLUMN Eclipse Cross; SE, SEL; w/Heated Strg. Wheel; Includes: Headlamp, Wiper & Turn Signal Switch.
    6370C408 CYL & KEYS - Lock & Hardware - CYLINDER,STEERING LOCK
    4408A177 IGNITION SWITCH - Shroud, Switches & Levers - SWITCH ASSYENG STARTIN
    4408A168 IGNITION SWITCH BOLT
    4408A151 IGNITION SWITCH CLAMP - Shroud, Switches & Levers - BRACKETSTEERING LOCK
    8065A124XA LOWER CLMN COVER w/o paddle shifters - Shroud, Switches & Levers - COVERSTEERING COLUMNL
    8065A123XA LOWER CLMN COVER w/paddle shifters - Shroud, Switches & Levers - COVERSTEERING COLUMNL
    По каталогу ASA для РФ
    4422A139 рулевой наконечник Mitsubishi Eclipse Cross
    4422A143 рулевая тяга Mitsubishi Eclipse Cross
  1. Ответов: 26
  2. Ответов: 29
  3. Ответов: 4
  4. Ответов: 42
