Показано с 1 по 5 из 5
Тема: Аудиосистема Rockford Fosgate Mitsubishi Eclipse Cross
    Система Rockford Fosgate Mitsubishi Eclipse Cross.
    Описание из сервисмануала (8 динамиков и саб):
    For Smartphone Link Display Audio, the multivision display with multivision display (6.95-inch wide display) is established.
    The touchpad controller is placed in the front floor console to enable safe and comfortable operation.<some models>
    On the spoke of steering wheel, the steering wheel remote control switch has been installed.
    An USB adapter is equipped in the centre lower box.
    The hands-free interface system has been established <some models>.
    A shark fin antenna has been mounted for receiving radio broadcast.
    The Rockford Fosgate® premium sound system (audio amplifier and 9 speakers at 7 positions) has been established.
    9 speakers (tweeter, front door, rear door, subwoofer) are provided <vehicles with Rockford Fosgate® premium sound system>.
    Общее описание системы Rockford Fosgate Mitsubishi Eclipse Cross
    The premium sound system applies "Rockford Fosgate®", American top car audio brand, as same as current model. All the electronics devices, circuits, like audio unit and premium amplifier, and sound structures, such as door speakers and subwoofer are newly developed. And the sound system is tuned thoroughly by professional Mitsubishi and Rockford engineers, the Rockford Fosgate® premium sound system accomplished higher sound quality than the current model having high reputation at world wide markets.
    FUNCTION
    Various attractive new sound adjusting functions are added, to select sound setting precisely, according to various user preferences.
    Surround technology: DTS Neural Surround
    Multi-channel surround enhancement technology developed by DTS, surround sound from the rear speakers, even 2-channel music source.
    Media expander: PremiDIA-HD
    Compensate sound quality of the compressed digital music source.
    Automatic volume control technology: Dolby Volume
    Auto volume level adjusting technology developed by Dolby, reduce volume changes between different volume level source.
    Wide stereo technology: PremiDIA-WIDE
    Emphasize stereo image more expanded, beyond cabin space.
    Listening Position selector
    Sound quality optimization according to the location of the listeners.
    3 levels speed compensated volume (SCV)
    Select from 3 levels of SCV effect (+OFF) accordingly from driving noise (current model: fixed value, SCV ON or OFF).
    Миниатюры Миниатюры Аудиоподготовка Эклипс Кросс.jpg‎
    Усилитель Rockford Fosgate Mitsubishi Eclipse Cross
    8-ми канальный, максимальная мощность 710 Вт
    As a separate amplifier, 8-ch audio amplifier incorporating digital signal processor (total maximum output of 710W) has been introduced.
    By using AUREUS® 32 bit digital signal processor and BURR-BROWN® 24 bit D/A converter, system has higher accretion of digital sound processing, and it makes predominantly clear sound.
    Динамики Rockford Fosgate Mitsubishi Eclipse Cross
    9 speakers [tweeter, front door, rear door (2-way), subwoofer] are provided.
    SPECIFICATIONS
    • Tweeter
      Allowable input power 50W
      Rated input power 25W
    • Front door speaker
      Allowable input power 80W
      Rated input power 40W
    • Rear door speaker
    • Subwoofer
      Allowable input power 150/150W
      Rated input power 75/75W
    TWEETER
    The 3.5 cm soft dome tweeters are incorporated in the instrument panel upper side.
    By placing it on the instrument panel facing upward, the sound is reflected by the glass and diffused to improve the feeling of being surrounded by sound.
    By using light weight CCAW (Copper-Clad Aluminium Wire) voice coil and Tetoron® diaphragm, making much clear and comfortable high frequency sound.
    DOOR SPEAKER
    The 16 cm polypropylene cone speakers (woofer) are incorporated in the front door. The 16 cm + 3.5 cm polypropylene cone 2-way coaxial speakers (woofer + tweeter) are incorporated in the rear door.
    Vacuum moulded 3D shape cone woofer has advantages for lighter weight and higher stiffness. By making horn shaped surrounding of the tweeter, makes sound connection smoothly from low to high frequency.
    SUBWOOFER
    The 25 cm dual voice coil subwoofer has been installed to the quarter trim in the luggage room, enabling the playback of dynamic deep bass.
    Gain more power than current model although subwoofer unit size is same. Position and direction of it are decided enthusiastically for excellent sound.
    DOOR AS A SPEAKER BOX
    By covering door inner service holes (deadening), the sound especially base become more real.
    Коды акустики системы Rockford Fosgate Mitsubishi Eclipse Cross
    8701A500 AMPLIFIER, RADIO усилитель Rockford Fosgate Mitsubishi Eclipse Cross
    8720A191 BOX, RR SPEAKER сабвуфер Rockford Fosgate Mitsubishi Eclipse Cross
    8720A202 SPEAKER, FR, 3.5CM твиттер
    8720A155 SPEAKER, FR DOOR, 40W, 16CM динамик передней двери
    8720A157 SPEAKER, RR DOOR, 40W, 16CM динамик задней двери
  1. Аудиосистема Mitsubishi Power Sound System (MPSS) Mitsubishi Eclipse Cross
    Ответов: 4
    Последнее сообщение: 30.12.2021, 09:04
  2. Ответов: 22
  3. Ответов: 4
  4. Ответов: 42
