Display content |
Message |
Factor |
Action procedure |
RBS SERVICE REQUIRED |
Displayed when the Regenerative brake is defective. |
If the warning screen is not displayed normally or if the screen continues to be displayed, check the regenerative brake system diagnosis code. Refer to GROUP 22D - Diagnosis Code Chart |
CHARGING SYSTEM SERVICE REQUIRED |
Displayed when fuel level or drive battery charged level is low. |
If the warning screen is not displayed normally or if the screen continues to be displayed, perform the troubleshooting for the BMU, Drive battery. Refer to GROUP 54D - Diagnosis code chart |
LIMITED DRIVING MODE |
Displayed when drive limitations are activated as the drive battery charged level is low or the plug-in hybrid EV system is too hot or cold. |
BATTERY TOO COLD |
Displayed when the temperature in the module reduces to -30°C or less. |
EV SYSTEM SERVICE REQUIRED |
Displayed when errors occur in the plug-in hybrid EV system (however, the vehicle can be driven). |
If the warning screen is not displayed normally or if the screen continues to be displayed, perform the troubleshooting for the PHEV-ECU. Refer to GROUP 54D - Diagnosis code chart |
EV SYSTEM SERVICE REQUIRED STOP SAFELY |
Displayed when errors occur in the plug-in hybrid EV system (the vehicle cannot be driven). |
EV SYSTEM OVERHEATING |
Displayed when the plug-in hybrid EV system is overheated. |
LOW MAIN BATTERY |
Displayed when the drive battery charged level is low as the selector lever is at "N" position for a long time. |
If the warning screen is not displayed normally or if the screen continues to be displayed, check the electrical parking driver unit diagnosis code. Refer to GROUP 22D - Diagnosis Code Chart |
SHIFT TO P POSITION |
Displayed when the selector lever is at any position other than "P" while the plug-in hybrid EV system is deactivated. |
P LOCK MALFUNCTION
WHEN PARKING, APPLY PARKING BRAKE SECURELY |
Displayed when the electric motor unit cannot be deactivated because there is a fault with the parking switch. |
ENGINE STARTED TO MAINTAIN FUEL SYSTEM |
Displayed when the system starts the engine forcibly to consume deteriorated fuel because the engine has not run for a long time. |
If the warning screen is not displayed normally or if the screen continues to be displayed, perform the troubleshooting for the engine. Refer to GROUP 13E - Trouble Symptom Chart |
READY TO REFUEL |
Displayed when the fuel filler lid is opened automatically after the closed fuel tank is depressurised. |
If the warning screen is not displayed normally or if the screen continues to be displayed, perform the troubleshooting for the ETACS. Refer to ==> |
CLOSE FUEL LID AND CAP |
Displayed when the charging port courtesy is open. |
TURN OFF BEFORE REFUEL |
Displayed when the fuel lid opener switch is operated while the power supply mode of the electric motor switch is at any position other than OFF. |
If the warning screen is not displayed normally or if the screen continues to be displayed, perform the troubleshooting for the OSS. Refer to GROUP 42B - Diagnosis code chart |
DISCONNECT CHARGE CABLE |
Displayed when you attempt to turn on the power supply mode of the electric motor switch while a charging connector (gun) is connected to the charging connector. |
CHARGE INTERRUPTED BY SYSTEM MALFUNCTION |
Displayed when the battery charging is cancelled because there is an error (electric leakage) in the system. |
If the warning screen is not displayed normally or if the screen continues to be displayed, perform the troubleshooting for the BMU, Drive battery. Refer to GROUP 54D - Diagnosis code chart . |
CHARGE INTERRUPTED BY POWER CABLE DISCONNECTION OR POWER SUPPLY FAILURE |
Displayed when the charging cable is connected improperly or the battery charging is cancelled due to power failure. |
CHARGE COMPLETE |
Displayed when the drive battery has been charged fully. |
