Кто сталкивался с заменой балансировочных валов? На каком пробеге? Есть альтернатива?
Двигатель какой? 4HK? 4HN? 4N14?
Что именно интересует? Признаки замены?
BALANCER SHAFT AND OIL PUMP MODULE REMOVAL AND INSTALLATION M111200890026300ENG
INSTALLATION SERVICE POINT
>>A<< COUPLING/BALANCER SHAFT AND OIL PUMP MODULE/BALANCER UNIT BOLT INSTALLATION
1.Align the timing marks on the balancer shaft, balancer shaft drive housing, and gear assembly with the positions shown on the figure, and install the balancer shaft and oil pump module.
2.Apply an adequate and minimum amount of engine oil to the thread of the balancer unit bolt and the lower area of the flange.
3.Tighten the balancer unit bolts to the specified torque (20 N·m) in the order shown in the figure.
4.
Caution:
- When the tightening angle is smaller than the specified tightening angle, the appropriate tightening capacity cannot be secured.
- When the tightening angle is larger than the specified tightening angle, remove the bolt to start from the beginning again according to the procedure.
Using the special tool angle gauge (MB991614), additionally tighten the balancer unit bolts 60°.
Познавательная статья о балансирных валах
Для 2.2 дизеля 4HK (4HN)
Citroen/Peugeot 0512 34 БЛОК УРАВНОВЕШИВАЮЩИХ ВАЛОВ
Замена артикула - 98 046 335 80
Применяется на автомобилях:
CITROEN
С-CROSSER (2007-) 2.2HDi(2007-)(2007-)
C6(2005-) 2.2HDi(2006-)(2006-)
C8(2002-) 2.2HDi(2002-)(2006-)
C5(2004-) 2.2HDi(RC4HXE)(2004-)(2004-). 2.2HDi(2006-)(2006-)
PEUGEOT
4007(2007-) 2.2HDi(2007-)(2007-)
607(2000-) 2.2HDi(2000-)(2006-)
807(2002-) 2.2HDi(2002-)(2006-)
407(2004-) 2.2(2004-)(2004-). 2.2 16V(2005-)(2005-)
Подбор прокладок под блок баллансирных валов
BALANCE SHAFTS
3-1. IDENTIFICATION
The balance shafts housing on the 4HN engine includes the oil pump fixings, at "k."
"l" reference holes for fitting the balance shafts.
"j" marking zone for balance shafts.
3-2. ADJUSTMENT
The operating clearances of the balance shafts of between 0.01 and 0.06 mm are obtained by the use of spacers placed between the cylinder block and the balance shafts housing.
3-3. SPECER THICKNESS
Всем привет, ребята подскажите пожалуйста митсубиси аутлендер 2008 года 2.2 di-d dw12 менял поршневые кольца, все собрал, завел, вроде бы все нормально но стала вибрация двигателя, грешу на успокоительные валы которые в потдоне, вопрос есть ли там какие нибудь метки?
Есть там особенности при сборке.
В мануале 2008 модельного года такой инфы не нашел, а вот в мануалах 2009 и 2010 модельных годов она имеется.
Вот читайте >>>>>> OIL PAN AND OIL PUMP.pdf<<<<<<
Картинки правда плохого разрешения, но можете сами найти мануал Аутлендера 2009 или 2010 мод.года и
в разделе 11H-ENGINE OVERHAUL<4HN> ---> OIL PAN AND OIL PUMP ---> OIL PAN AND OIL PUMP REMOVAL AND INSTALLATION ---> REMOVAL AND INSTALLATION найдете эту информацию.
Это текстовка из инструкции касательно балансирных валов:
3.Position the blind holes "n" of the balance shafts upwards.
4.Introduce the 5 mm diameter pins of the tool [44] into the blind holes "n".
5.Install the tool clamp [45] on the tool [44].
6.Gently tighten the screw of the tool [45].
7.Refit the balance shaft housing (25).
8.Engage the balance shaft housing (25) on its centring pins.
9.Remove the tool bearing cap positioning tool kit MB996219 [45], [44].
10.Remove the tool the engine flywheel peg [9].
Это гугль перевод:
3.Расположите глухие отверстия "n" балансовых валов вверх.
4.Введите штифты инструмента диаметром 5 мм [44] в глухие отверстия "n".
5.Установите зажим инструмента [45] на инструмент [44].
6.Осторожно затяните винт инструмента [45].
7.Установите баланс вала (25).
8.Вести баланс вала (25) на центрирующие штифты.
9.Снимите инструментальную крышку подшипника positioning toolkit MB996219 [45], [44].
10.Снять стопорный инструмент маховика ПЭГ [9].
Последний раз редактировалось Бекас; 27.01.2019 в 23:10.
Вот картинки по балансирам из мануала чуток покрупнее:
Балансиры 1.pdf
Балансиры 2.pdf
Балансиры 3.pdf
Балансиры 4.pdf
